Ir para o conteúdo principal
HP 7 Plus 1302 Speaker Replacement
O que você precisa
  1. HP 7 Plus 1302 Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Speaker Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Speaker Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Speaker Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Speaker Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Speaker Replacement, Speaker: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to push out the speaker connector.
  5. HP 7 Plus 1302 Speaker Replacement: passo 5, imagem 1 %32
    • A thin strip of double sided tape secure sthe speaker to the device and is located beneath the speaker.
    • Use the flat end of spudger to pry out the speaker
    • Be careful when working the speaker away from the double-sided tape. Excessive force may damage the component.
  6. HP 7 Plus 1302 Speaker Replacement: passo 6, imagem 1 %32
    • Lift the speaker away from the device and replace it with the new one.
Conclusão
junlin16
Membro desde: 07/07/15
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-2, Renguette SU 2015 Membro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 227
