Introdução
This guide will help you to replace your broken speaker step by step. Be very careful when you remove your speaker, since using excessive force may cause damage.
O que você precisa
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Use tweezers to push out the speaker connector.
Quase terminado!
Conclusão
