Ir para o conteúdo principal
HP 7 Plus 1302 Power and Volume Button Replacement
O que você precisa
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: passo 4, imagem 1 %32
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, imagem 2 %32
    • Pop out the power and volume buttons with your hands
Conclusão
Shannon Suttles
Membro desde: 01/29/17
225 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-4, Baechle Spring 2017 Membro de IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 283
