Ir para o conteúdo principal
HP 7 Plus 1302 Motherboard Replacement
O que você precisa
  1. HP 7 Plus 1302 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Motherboard Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Motherboard Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Motherboard Replacement, Battery: passo 4, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement, Battery: passo 4, imagem 2 %32
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Motherboard Replacement: passo 5, imagem 1 %32
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Motherboard Replacement: passo 7, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 7, imagem 2 %32
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Motherboard Replacement: passo 8, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 8, imagem 2 %32
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Motherboard Replacement: passo 9, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Motherboard Replacement: passo 10, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 10, imagem 2 %32
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Motherboard Replacement: passo 11, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 11, imagem 2 %32 HP 7 Plus 1302 Motherboard Replacement: passo 11, imagem 3 %32
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Motherboard Replacement: passo 13, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 13, imagem 2 %32
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Motherboard Replacement: passo 14, imagem 1 %32 HP 7 Plus 1302 Motherboard Replacement: passo 14, imagem 2 %32
    • Pull the circuit board off.
Conclusão
Equipe
IUPUI, Team 1-4, Baechle Spring 2017 Membro de IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 186
