Ir para o conteúdo principal
HP 7 Plus 1302 Battery Replacement
O que você precisa
  1. HP 7 Plus 1302 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Battery Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Battery Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Battery Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Battery Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Battery Replacement, Battery: passo 4, imagem 1 %32 HP 7 Plus 1302 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery from the device.
Conclusão
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Uma outra pessoa concluiu este guia.
Jason
Membro desde: 07/07/15
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-2, Renguette SU 2015 Membro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,797
