Ir para o conteúdo principal
HP 7 PLUS 1301 Volume / Power Button Replacement
O que você precisa
  1. HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: passo 1, imagem 1 %32 HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: passo 1, imagem 2 %32
    • Make sure the device is off and not plugged in before starting.
    • Use the T5 Torx screwdriver and remove the T5x3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 2, imagem 1 %32 HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 3, imagem 1 %32 HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 4, imagem 1 %32
    • The power and volume buttons are on the side of the device. Locate these buttons to begin the replacement process.
  5. HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 5, imagem 1 %32 HP 7 PLUS 1301 Volume / Power Button  Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Gently push out the power and volume buttons with tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Adanna Ilori
Membro desde: 02/05/19
301 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S20-G6, Lore Winter 2019 Membro de UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 271
