Ir para o conteúdo principal
HP 7 PLUS 1301 Speaker Replacement
O que você precisa
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: passo 1, imagem 1 %32 HP 7 PLUS 1301 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Speaker Replacement: passo 2, imagem 1 %32 HP 7 PLUS 1301 Speaker Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Speaker Replacement: passo 3, imagem 1 %32 HP 7 PLUS 1301 Speaker Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Speaker Replacement: passo 4, imagem 1 %32 HP 7 PLUS 1301 Speaker Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully remove the speaker connector from the socket.
  5. HP 7 PLUS 1301 Speaker Replacement: passo 5, imagem 1 %32 HP 7 PLUS 1301 Speaker Replacement: passo 5, imagem 2 %32 HP 7 PLUS 1301 Speaker Replacement: passo 5, imagem 3 %32
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Shao-Hung Hsiao
Membro desde: 02/05/19
201 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S20-G6, Lore Winter 2019 Membro de UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 137
