Ir para o conteúdo principal
HP 7 1800 Motherboard Replacement
O que você precisa
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: passo 1, imagem 1 %32 HP 7 1800 Motherboard Replacement, Remove the back panel: passo 1, imagem 2 %32
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: passo 2, imagem 1 %32 HP 7 1800 Motherboard Replacement, Remove the battery: passo 2, imagem 2 %32 HP 7 1800 Motherboard Replacement, Remove the battery: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: passo 3, imagem 1 %32 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: passo 3, imagem 2 %32
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: passo 4, imagem 1 %32 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: passo 4, imagem 2 %32
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: passo 5, imagem 1 %32
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: passo 6, imagem 1 %32
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: passo 7, imagem 1 %32
    • Carefully lift the motherboard directly up.
Conclusão
TMD
Membro desde: 01/21/15
765 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-1, Brown Winter 2015 Membro de USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
Membros da 4
Autoria de 14 guias
Um comentário
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 981
