Ir para o conteúdo principal
HP 7 1800 Battery Replacement
O que você precisa
  1. HP 7 1800 Battery Replacement, Remove the back panel: passo 1, imagem 1 %32 HP 7 1800 Battery Replacement, Remove the back panel: passo 1, imagem 2 %32
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: passo 2, imagem 1 %32 HP 7 1800 Battery Replacement, Remove the battery: passo 2, imagem 2 %32 HP 7 1800 Battery Replacement, Remove the battery: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
TMD
Membro desde: 01/21/15
765 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-1, Brown Winter 2015 Membro de USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
Membros da 4
Autoria de 14 guias
2 comentários
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - Responder
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 3,422
