Ir para o conteúdo principal
HP 24-G014 disassembly
  1. HP 24-G014 disassembly, The Stand: passo 1, imagem 1 %32 HP 24-G014 disassembly, The Stand: passo 1, imagem 2 %32
    • Flipping the device over here we see two Philips screws holding the stand to the computer.
    • Using a basic screw driver you will most likely find in your garage or a junk drawer we can remove these two screws.
  2. HP 24-G014 disassembly, Removing said stand: passo 2, imagem 1 %32
    • After removing the two screws you can pull off the stand.
  3. HP 24-G014 disassembly, Remove the screw inside the stand slot: passo 3, imagem 1 %32 HP 24-G014 disassembly, Remove the screw inside the stand slot: passo 3, imagem 2 %32
    • Inside the stand slot there is an extra screw using the same screw driver remove the screw.
  4. HP 24-G014 disassembly: passo 4, imagem 1 %32 HP 24-G014 disassembly: passo 4, imagem 2 %32 HP 24-G014 disassembly: passo 4, imagem 3 %32
    • After the screw in the stand slot is removed there are clips holding the display to the body of the system.
    • Using a prying tool such as an iFixit metal spudger or Jimmy tool you can lift the display from the body.
    • Don’t worry about accidentally striking the components as they are pretty far away except for the bottom since the speakers are there.
    • One last thing before going to the other step. I highly don’t recommend using something such as a big flat head screw driver, butter knife, or sharp knifes. But if you must you can use them.
  5. HP 24-G014 disassembly, Removing the Display from the body.: passo 5, imagem 1 %32
    • After unclipping the display from the body be very gentle! As there are wires and a display connector attached to the screen.
    • To prevent damage you should open the system from bottom to top (where the HP logo is).
Conclusão
That’s it you’re done!
I am not responsible for any damages done to your device if you break it during repair.
5 outras pessoas executaram este guia.
Hayden
Membro desde: 07/11/21
242 Reputação
Autoria de 1 guia
Equipe
The Odyssey Repair Group Membro de The Odyssey Repair Group
Community
Membros da 2
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 68
Duração total: 5,113
