Introdução
This guide will help you replace the battery of your HP 255 G7 laptop.
O que você precisa
Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
Use the spatula to remove the rubber "leg", all the way until it is completely removed.
Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
Locate and unscrew the 3x Philips 1 screws that hold the battery.
After unscrewing the 3 screws, pull the top side of the battery up then slide it out to remove it.
