Ir para o conteúdo principal
HP 2000 - 2D22DX Optical Drive Replacement
O que você precisa
  1. HP 2000 - 2D22DX Optical Drive Replacement, Battery: passo 1, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Optical Drive Replacement: passo 2, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 2, imagem 2 %32
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: passo 3, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Optical Drive Replacement: passo 4, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 4, imagem 2 %32
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Optical Drive Replacement: passo 5, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 5, imagem 2 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 5, imagem 3 %32
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Optical Drive Replacement: passo 6, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 6, imagem 2 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 6, imagem 3 %32
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Optical Drive Replacement: passo 7, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 7, imagem 2 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 7, imagem 3 %32
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
  8. HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: passo 8, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: passo 8, imagem 2 %32
    • Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle.
    • Use a #00 Phillips head screwdriver to remove the small screw. Consider using a magnetized screwdriver.
  9. HP 2000 - 2D22DX Optical Drive Replacement: passo 9, imagem 1 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 9, imagem 2 %32 HP 2000 - 2D22DX Optical Drive Replacement: passo 9, imagem 3 %32
    • Once the securing screw is removed, the optical drive can be pulled from its slot easily.
    • Use your fingers to pull the optical drive away slowly from its position in the plastic chassis.
    • The optical drive should slide out very easily. If you fell resistance, do not pull too hard. Something may be caught, and you might damage the optical drive's connections.
Conclusão
3 outras pessoas executaram este guia.
Conor Most
Membro desde: 04/14/14
2.687 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-40, Maness Spring 2014 Membro de Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 27
Duração total: 1,592
