Introdução
If your laptop slows down when using certain applications, you may need to replace or add RAM in an HP 17-x173dx. This guide will show you how to replace RAM in your laptop in easy-to-follow steps.
O que você precisa
Using the Phillips #0 screwdriver, remove fourteen 7 mm screws on the back of the device (two will be underneath where the battery was).
Quase terminado!
Install your replacement RAM and reassemble your device by following these instructions in reverse order.
Conclusão
