Ir para o conteúdo principal
HP 17-x061nr Battery Replacement
  1. HP 17-x061nr Battery Replacement, Battery: passo 1, imagem 1 %32 HP 17-x061nr Battery Replacement, Battery: passo 1, imagem 2 %32
    • With the power off, turn the laptop over.
    • The battery is located at the back of the laptop next to the screen hinges.
    • Move the locking tab on the right-hand side into the unlocked position by pushing it to the left. This tab will stay in the unlocked position.
  2. HP 17-x061nr Battery Replacement: passo 2, imagem 1 %32
    • Locate the spring loaded tab on the left-hand side and push to the right to unlock it.
    • Holding the tab in the unlocked position pull the battery out, away from the laptop.
Conclusão
Curtis Haley
Membro desde: 02/23/18
514 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,056
