Introdução
This guide will assist you in replacing the HP LCD Screen. You will need to replace the screen if your screen displays black and white lines over your homepage.
O que você precisa
Open the laptop so you can see the screen.
Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
Uma outra pessoa concluiu este guia.
