Ir para o conteúdo principal
HP 17-x027ds LCD Screen Replacement
O que você precisa
  1. HP 17-x027ds LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 HP 17-x027ds LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 HP 17-x027ds LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Open the laptop so you can see the screen.
    • Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
    • Remove the bezel by starting on the sides of the screen and lastly removing the top outlining.
    • When removing the bezel, be cautious not to use too much force or else you will damage the screen. Apply just enough pressure to create a gap between the bezel and screen.
  2. HP 17-x027ds LCD Screen Replacement: passo 2, imagem 1 %32 HP 17-x027ds LCD Screen Replacement: passo 2, imagem 2 %32 HP 17-x027ds LCD Screen Replacement: passo 2, imagem 3 %32
    • Lift the bezel off the screen to see the outlines of the LCD screen.
    • Remove the four black 3mm screws in each corner of the screen with a JIS #1 screwdriver.
    • Remove the two silver 4mm screws located at the top of the screen with a JIS #1 screwdriver.
  3. HP 17-x027ds LCD Screen Replacement: passo 3, imagem 1 %32 HP 17-x027ds LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the LCD screen and place it on the keyboard.
    • Disconnect the video cable to completely detach the LCD screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 648
