Ir para o conteúdo principal
HP 17-x027ds Hard Drive Replacement
O que você precisa
  1. HP 17-x027ds Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 17-x027ds Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP 17-x027ds Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top of the laptop.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32 HP 17-x027ds Hard Drive Replacement, Hard Drive: passo 2, imagem 2 %32 HP 17-x027ds Hard Drive Replacement, Hard Drive: passo 2, imagem 3 %32
    • Remove the two pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the two black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm JIS #1 screws.
  3. HP 17-x027ds Hard Drive Replacement: passo 3, imagem 1 %32 HP 17-x027ds Hard Drive Replacement: passo 3, imagem 2 %32
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Hard Drive Replacement: passo 4, imagem 1 %32 HP 17-x027ds Hard Drive Replacement: passo 4, imagem 2 %32 HP 17-x027ds Hard Drive Replacement: passo 4, imagem 3 %32
    • Disconnect the blue ends of the white ribbon cable by pulling the blue ends out of the connector.
    • The ribbon cable will still be connected to the rubber and just the ends will be disconnected.
  5. HP 17-x027ds Hard Drive Replacement: passo 5, imagem 1 %32 HP 17-x027ds Hard Drive Replacement: passo 5, imagem 2 %32
    • Lift the black rubber cover containing the hard drive by lifting the right side of the rubber cover.
    • The white ribbon cable will still be connected to the rubber cover, so remove the hard drive out from under.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,064
