O que você precisa
Using a phillips sccrew driver, remove the ten scews holding on bottom cover.
Using a screw driver seperate the back cover from the keyboard/computer.
Using phillips screw driver, remove the four screws and lift out battery.
Install new battery, Screw it in. When reassembling back cover, hold CD drive out about 3/4". After cover is in place, push CD drive into place,
Uma outra pessoa concluiu este guia.
