Ir para o conteúdo principal
HP 17-bs049dx RAM Replacement
O que você precisa
  1. HP 17-bs049dx RAM Replacement, Battery: passo 1, imagem 1 %32
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx RAM Replacement, Back Panel: passo 2, imagem 1 %32
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx RAM Replacement: passo 3, imagem 1 %32
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx RAM Replacement: passo 4, imagem 1 %32 HP 17-bs049dx RAM Replacement: passo 4, imagem 2 %32
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx RAM Replacement: passo 5, imagem 1 %32
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx RAM Replacement, RAM: passo 6, imagem 1 %32 HP 17-bs049dx RAM Replacement, RAM: passo 6, imagem 2 %32
    • To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures.
    • You will have to gently force it out to avoid breaking it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 801
