Introdução
During the process, be careful with the placement of removed screws. This back panel disassembly is required to access all internal components.
O que você precisa
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
5 outras pessoas executaram este guia.
