Ir para o conteúdo principal
HP 15-g071nr Hard Drive Replacement
O que você precisa
  1. HP 15-g071nr Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-g071nr Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the bottom is facing upwards.
  2. HP 15-g071nr Hard Drive Replacement: passo 2, imagem 1 %32 HP 15-g071nr Hard Drive Replacement: passo 2, imagem 2 %32
    • Press the tabs at the corners of the laptop at the same time to release the battery.
  3. HP 15-g071nr Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-g071nr Hard Drive Replacement: passo 3, imagem 2 %32 HP 15-g071nr Hard Drive Replacement: passo 3, imagem 3 %32
    • Pull the battery away from the laptop in one motion.
  4. HP 15-g071nr Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Using your Phillips #0 screwdriver, remove all of the screws on the back case.
  5. HP 15-g071nr Hard Drive Replacement: passo 5, imagem 1 %32 HP 15-g071nr Hard Drive Replacement: passo 5, imagem 2 %32 HP 15-g071nr Hard Drive Replacement: passo 5, imagem 3 %32
    • Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
    • Remove the wrist rest once it comes loose from the body.
  6. HP 15-g071nr Hard Drive Replacement: passo 6, imagem 1 %32 HP 15-g071nr Hard Drive Replacement: passo 6, imagem 2 %32 HP 15-g071nr Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the two screws with the Phillips #0.
    • Gently pull the hard drive out of its SATA connection to the motherboard.
    • Attach the loose data cable to the new drive.
    • Be careful not to damage the silver ribbon cable below the hard drive itself.
Conclusão
Emerson Tatelbaum
Membro desde: 11/01/19
543 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 892
