Ir para o conteúdo principal
HP 15-f162dx RAM Replacement
O que você precisa
  1. HP 15-f162dx RAM Replacement, RAM: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin the repair.
  2. HP 15-f162dx RAM Replacement: passo 2, imagem 1 %32
    • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
    • Remove it at an angle and not straight up so you don't damage the socket.
  3. HP 15-f162dx RAM Replacement: passo 3, imagem 1 %32
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM will pop up by a few millimeters.
    • Repeat steps in reverse order to reassemble the computer with new RAM
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 399
