Introdução
This is a guide on how to replace the hard drive of your HP 15-f162dx. Due to the assembly of the laptop, this process will require a substantial amount of disassembly and reassembly. Before beginning disassembly completely power off the laptop, remove the power cord, and unplug any external devices connected to the laptop.
O que você precisa
Place the laptop upside down on a hard flat surface.
Slide the right release latch to unlock the battery.
Slide the left release latch to release the battery.
Lift the battery up and away from the computer.
Slide your finger under the keyboard along the top edge of the keyboard to release the keyboard.
Swing the keyboard away from the screen and rest it on its face.
Release the ZIF connecter by lifting the connector tab connected to the keyboard cable.
Disconnect the keyboard cable.
Remove the keyboard.
Remove the screws shown.
Flip the laptop right side up and open the lid.
Insert the jimmy in between the top cover and the base and slide it along the edge of the laptop. Repeat for the opposite edge.
Swing the upper left and upper right corners away from the screen and lift the top cover away from the laptop.
3 outras pessoas executaram este guia.
