Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
In the case that the laptop does not respond to the adapter being plugged in, the power jack may be faulty. Follow this guide to replace the power jack.
Peças
Nenhum componente especificado.
  1. Turn power off using the power button located in the top left corner of the  keyboard. Press and hold the power button for 3 seconds until it turns off.
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop. Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. Locate the battery and the two switches that release the battery when they are unlocked. Locate the battery and the two switches that release the battery when they are unlocked.
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible. Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port. While holding the switch in place, use your right hand to gently remove the battery from its port. While holding the switch in place, use your right hand to gently remove the battery from its port.
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. Pry up and detach keyboard.
    • Pry up and detach keyboard.
  8. Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. Remove the palm rest using the blue spudger tool. Remove the palm rest using the blue spudger tool.
    • Remove the palm rest using the blue spudger tool.
  10. Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. Remove metal keyboard underlayment.
    • Remove metal keyboard underlayment.
  12. After removing the battery and the palm rest, remove the two 7 mm PH1 Phillips head screws holding in the small metal power jack holder.
    • After removing the battery and the palm rest, remove the two 7 mm PH1 Phillips head screws holding in the small metal power jack holder.
  13. Unplug the wired connection from the laptop to the power jack. Detach broken power jack using blue spudger.
    • Unplug the wired connection from the laptop to the power jack.
    • Detach broken power jack using blue spudger.
Conclusão
3 outras pessoas concluíram este guia.
Aaron Chabot
Membro desde: 17/10/2017
565 Reputação
4 Guias de autoria
Equipe
I have hp pavilion 15xxxxxx i3 laptop. Its power jack was damaged. I replaced it. When I connected it with power, the light on the jack blinks one time then turned off. Every time I connect it with power, same thing happens. It is neither charging the batyery nor turning the laptop on. Can anyo e tell me what is the issue and how to solve.
Thanks.
AbdulHafeez.
Abdulhafeez Anjum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 63
Duração total: 2,857
