Ir para o conteúdo principal
HP 15-f009wm Hard Drive Replacement
O que você precisa
  1. HP 15-f009wm Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-f009wm Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Hard Drive Replacement: passo 2, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 2, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 2, imagem 3 %32
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the battery out.
  4. HP 15-f009wm Hard Drive Replacement, RAM: passo 4, imagem 1 %32 HP 15-f009wm Hard Drive Replacement, RAM: passo 4, imagem 2 %32 HP 15-f009wm Hard Drive Replacement, RAM: passo 4, imagem 3 %32
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Hard Drive Replacement: passo 5, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 5, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Hard Drive Replacement: passo 6, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 6, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 6, imagem 3 %32
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Hard Drive Replacement, Hard Drive: passo 8, imagem 1 %32
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Hard Drive Replacement: passo 9, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 9, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 9, imagem 3 %32
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Hard Drive Replacement: passo 10, imagem 1 %32
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Hard Drive Replacement: passo 11, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 11, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 11, imagem 3 %32
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Hard Drive Replacement: passo 12, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 12, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 12, imagem 3 %32
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Hard Drive Replacement: passo 13, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 13, imagem 2 %32
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Hard Drive Replacement: passo 14, imagem 1 %32
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Hard Drive Replacement: passo 15, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 15, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 15, imagem 3 %32
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Hard Drive Replacement: passo 16, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 16, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 16, imagem 3 %32
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Hard Drive Replacement: passo 17, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 17, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 17, imagem 3 %32
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Hard Drive Replacement: passo 18, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 18, imagem 2 %32
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Hard Drive Replacement: passo 19, imagem 1 %32 HP 15-f009wm Hard Drive Replacement: passo 19, imagem 2 %32 HP 15-f009wm Hard Drive Replacement: passo 19, imagem 3 %32
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
Conclusão
9 outras pessoas executaram este guia.
Alex Birchler
Membro desde: 02/14/18
1.008 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G2, Nance Spring 2018 Membro de USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
Membros da 4
Autoria de 5 guias
3 comentários
This guide helped me so much with my laptop, thanks m8
Connor Cornelison - Responder
Thank you for this excellent write-up!
Dan Snow - Responder
Hello, i have a question. How much of capacity and technology i could use to upgrade my hard drive?
Samuel Arreaza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Duração total: 3,843
