Pular para o conteúdo principal
Introdução
Use this guide if your battery in your HP 15-009wm is not working and needs to be replaced. To reduce the risk of electric shock, the battery should be removed before any other repairs are made.
  1. Turn laptop upside down. Flip the lock switch to the unlocked setting.
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Flip the release switch. Once the flip is switched, the battery should pop out. Once the flip is switched, the battery should pop out.
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  4. Slide the battery out. Slide the battery out.
    • Slide the battery out.
Conclusão
Alex Birchler
Membro desde: 14-02-2018
733 reputação
5 Guias de autoria
Equipe
USF Tampa, Team S2-G2, Nance Spring 2018 Membro de USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 101
