Ir para o conteúdo principal
HP 15-ef2025nr Fan Replacement
O que você precisa
  1. HP 15-ef2025nr Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: passo 2, imagem 1 %32 HP 15-ef2025nr Fan Replacement: passo 2, imagem 2 %32
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: passo 3, imagem 1 %32 HP 15-ef2025nr Fan Replacement: passo 3, imagem 2 %32
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: passo 4, imagem 1 %32 HP 15-ef2025nr Fan Replacement: passo 4, imagem 2 %32
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: passo 5, imagem 1 %32 HP 15-ef2025nr Fan Replacement: passo 5, imagem 2 %32 HP 15-ef2025nr Fan Replacement: passo 5, imagem 3 %32
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: passo 6, imagem 1 %32 HP 15-ef2025nr Fan Replacement, Fan: passo 6, imagem 2 %32 HP 15-ef2025nr Fan Replacement, Fan: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: passo 7, imagem 1 %32 HP 15-ef2025nr Fan Replacement: passo 7, imagem 2 %32 HP 15-ef2025nr Fan Replacement: passo 7, imagem 3 %32
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
Conclusão
kyle mccomas
Membro desde: 02/13/23
291 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 179
