Ir para o conteúdo principal
HP 15-dy2024nr Battery Replacement
O que você precisa
  1. HP 15-dy2024nr Battery Replacement, Back Cover: passo 1, imagem 1 %32 HP 15-dy2024nr Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Battery Replacement: passo 2, imagem 1 %32 HP 15-dy2024nr Battery Replacement: passo 2, imagem 2 %32 HP 15-dy2024nr Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Battery Replacement: passo 3, imagem 1 %32 HP 15-dy2024nr Battery Replacement: passo 3, imagem 2 %32 HP 15-dy2024nr Battery Replacement: passo 3, imagem 3 %32
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Battery Replacement, Battery: passo 4, imagem 1 %32 HP 15-dy2024nr Battery Replacement, Battery: passo 4, imagem 2 %32 HP 15-dy2024nr Battery Replacement, Battery: passo 4, imagem 3 %32
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Battery Replacement: passo 5, imagem 1 %32 HP 15-dy2024nr Battery Replacement: passo 5, imagem 2 %32 HP 15-dy2024nr Battery Replacement: passo 5, imagem 3 %32
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
Conclusão
Konnor Young
Membro desde: 09/27/22
523 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 19
Últimos 30 dias: 42
Duração total: 687
