Ir para o conteúdo principal
HP 15-db0015dx Hard Drive Replacement
O que você precisa
  1. HP 15-db0015dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-db0015dx Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx Hard Drive Replacement: passo 2, imagem 1 %32 HP 15-db0015dx Hard Drive Replacement: passo 2, imagem 2 %32 HP 15-db0015dx Hard Drive Replacement: passo 2, imagem 3 %32
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-db0015dx Hard Drive Replacement: passo 3, imagem 2 %32 HP 15-db0015dx Hard Drive Replacement: passo 3, imagem 3 %32
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 HP 15-db0015dx Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 HP 15-db0015dx Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
Conclusão
6 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 56
Ao todo: 4,378
