Ir para o conteúdo principal
HP 15-da0012dx SSD Replacement
O que você precisa
  1. HP 15-da0012dx SSD Replacement, Battery: passo 1, imagem 1 %32 HP 15-da0012dx SSD Replacement, Battery: passo 1, imagem 2 %32
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: passo 2, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 2, imagem 2 %32 HP 15-da0012dx SSD Replacement: passo 2, imagem 3 %32
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: passo 3, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 3, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: passo 4, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 4, imagem 2 %32
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: passo 5, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 5, imagem 2 %32 HP 15-da0012dx SSD Replacement: passo 5, imagem 3 %32
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: passo 6, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 6, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: passo 7, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 7, imagem 2 %32
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: passo 8, imagem 1 %32 HP 15-da0012dx SSD Replacement, SSD: passo 8, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: passo 9, imagem 1 %32 HP 15-da0012dx SSD Replacement: passo 9, imagem 2 %32
    • Pull the SSD module away from the socket.
Conclusão
5 outras pessoas executaram este guia.
Xavier Hung
Membro desde: 02/07/19
914 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S20-G4, Lore Winter 2019 Membro de UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
Membros da 3
Autoria de 7 guias
Um comentário
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 73
Duração total: 8,904
