Ir para o conteúdo principal
HP 15-da0012dx Battery Replacement
O que você precisa
  1. HP 15-da0012dx Battery Replacement, Battery: passo 1, imagem 1 %32 HP 15-da0012dx Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Battery Replacement: passo 2, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 2, imagem 2 %32 HP 15-da0012dx Battery Replacement: passo 2, imagem 3 %32
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Battery Replacement: passo 3, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 3, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Battery Replacement: passo 4, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 4, imagem 2 %32
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Battery Replacement: passo 5, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 5, imagem 2 %32 HP 15-da0012dx Battery Replacement: passo 5, imagem 3 %32
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Battery Replacement: passo 6, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 6, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Battery Replacement: passo 7, imagem 1 %32 HP 15-da0012dx Battery Replacement: passo 7, imagem 2 %32
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
Conclusão
6 outras pessoas executaram este guia.
Xavier Hung
Membro desde: 02/07/19
914 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S20-G4, Lore Winter 2019 Membro de UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
Membros da 3
Autoria de 7 guias
4 comentários
Where to find, buy the same battery.
Divya Lekha - Responder
Where r living. We can help you which website you buy this battery
Mahima Singh -
Thank you for the guide! =D
Kevin - Responder
If you are living in Delhi ncr. We provide him service and delivery of hp ht03xl battery at very reasonable price at your office and home. Our home service executive will help you to assemble this battery. Nice description details about here. How to replace hp original battery.
Mahima Singh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 46
Últimos 30 dias: 188
Duração total: 13,083
