Ir para o conteúdo principal
HP 15-da0002dx RAM Replacement
O que você precisa
  1. HP 15-da0002dx RAM Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx RAM Replacement: passo 2, imagem 1 %32
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx RAM Replacement: passo 3, imagem 1 %32 HP 15-da0002dx RAM Replacement: passo 3, imagem 2 %32
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx RAM Replacement: passo 4, imagem 1 %32
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx RAM Replacement: passo 5, imagem 1 %32
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx RAM Replacement: passo 6, imagem 1 %32 HP 15-da0002dx RAM Replacement: passo 6, imagem 2 %32
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx RAM Replacement: passo 7, imagem 1 %32
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx RAM Replacement, Battery: passo 8, imagem 1 %32
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx RAM Replacement: passo 9, imagem 1 %32 HP 15-da0002dx RAM Replacement: passo 9, imagem 2 %32
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx RAM Replacement, RAM: passo 10, imagem 1 %32
    • The retention clips are located on either side of the RAM module. Spread them away from each other until you hear a clicking sound.
  11. HP 15-da0002dx RAM Replacement: passo 11, imagem 1 %32 HP 15-da0002dx RAM Replacement: passo 11, imagem 2 %32
    • Pull the RAM module away from the slot.
Conclusão
7 outras pessoas executaram este guia.
Abigail Aron
Membro desde: 09/04/19
1.124 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 1,545
