Introdução
This guide details how to replace the motherboard on an HP 15-d076nr. If your laptop suffered liquid damage and is not working properly, the motherboard could be fried. This may be the guide for you.
O que você precisa
Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
Locate the left and right switches at the bottom of the laptop.
Re-orient the laptop, so that the back of the laptop faces away from you.
Um comentário
H! May I have the part number of the LCD flex cable? or can you send me a picture of it? Thanks.
