Ir para o conteúdo principal
HP 15-ba0709dx Hard Drive Replacement
O que você precisa
  1. HP 15-ba0709dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Hard Drive Replacement, Back Cover: passo 3, imagem 1 %32
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Hard Drive Replacement: passo 4, imagem 1 %32
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Hard Drive Replacement: passo 5, imagem 1 %32
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Hard Drive Replacement: passo 6, imagem 1 %32 HP 15-ba0709dx Hard Drive Replacement: passo 6, imagem 2 %32
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Hard Drive Replacement: passo 8, imagem 1 %32 HP 15-ba0709dx Hard Drive Replacement: passo 8, imagem 2 %32
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
  9. HP 15-ba0709dx Hard Drive Replacement, Hard Drive: passo 9, imagem 1 %32
    • Locate the square, blue hard drive
    • Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
  10. HP 15-ba0709dx Hard Drive Replacement: passo 10, imagem 1 %32
    • Lift the hard drive out of its slot after screws are removed.
  11. HP 15-ba0709dx Hard Drive Replacement: passo 11, imagem 1 %32
    • Squeeze to release and pull adapter cable from the side of hard drive.
    • Be careful not to damage the adapter.
Conclusão
5 outras pessoas executaram este guia.
Lydia Brown
Membro desde: 03/20/17
369 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S13-G3, Bennett Spring 2017 Membro de Texas Tech, Team S13-G3, Bennett Spring 2017
TTU-BENNETT-S17S13G3
Membros da 5
Autoria de 5 guias
Um comentário
Many thanks for this! The adhesive pads were foiling my attempts, and I was afraid of breaking things. Perfect instructions, I accomplished my goal :)
Diana K - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 24
Duração total: 5,369
