Ir para o conteúdo principal
HP 15-ay103dx Display Screen Hinges Replacement
O que você precisa
  1. HP 15-ay103dx Display Screen Hinges Replacement, Battery: passo 1, imagem 1 %32
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay103dx Display Screen Hinges Replacement: passo 2, imagem 1 %32
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay103dx Display Screen Hinges Replacement, Back Panel: passo 3, imagem 1 %32
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay103dx Display Screen Hinges Replacement: passo 4, imagem 1 %32
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay103dx Display Screen Hinges Replacement: passo 5, imagem 1 %32 HP 15-ay103dx Display Screen Hinges Replacement: passo 5, imagem 2 %32
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay103dx Display Screen Hinges Replacement: passo 6, imagem 1 %32 HP 15-ay103dx Display Screen Hinges Replacement: passo 6, imagem 2 %32
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay103dx Display Screen Hinges Replacement: passo 7, imagem 1 %32
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: passo 8, imagem 1 %32 HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: passo 8, imagem 2 %32
    • Use a spudger to carefully remove the border around the display screen.
    • As long as you are slow and delicate, the border will eventually come off.
  9. HP 15-ay103dx Display Screen Hinges Replacement: passo 9, imagem 1 %32 HP 15-ay103dx Display Screen Hinges Replacement: passo 9, imagem 2 %32
    • Remove the two 5/16 screws in the top corners and the four in the bottom corners.
  10. HP 15-ay103dx Display Screen Hinges Replacement: passo 10, imagem 1 %32
    • Carefully pull the screen from the hinges and lower it on to the table.
    • There will be wires running from the screen to the motherboard. You do not need to unplug these.
    • The hinges are made of malleable metal and are easily bent.
  11. HP 15-ay103dx Display Screen Hinges Replacement: passo 11, imagem 1 %32
    • Remove the 5/16 screws securing the hinges to the computer.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 789
