Introdução
This is a guide on removing and replacing an additional USB port that is not attached to the motherboard. The other USB ports that are on the motherboard have to be replaced with a new motherboard or with advanced soldering skills.
O que você precisa
Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
Remove the rubber feet on the bottom of the device to access all the screws.
Quase terminado!
Conclusão
