Introdução
This guide will show you how to safely remove the RAM in your HP 15-ay014dx laptop for replacement.
O que você precisa
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
7 outras pessoas executaram este guia.
