Ir para o conteúdo principal
HP 15-ay014dx Hard Drive Disk Replacement
O que você precisa
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: passo 1, imagem 1 %32
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: passo 2, imagem 1 %32
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: passo 3, imagem 1 %32
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: passo 4, imagem 1 %32
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: passo 5, imagem 1 %32
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: passo 6, imagem 1 %32 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: passo 6, imagem 2 %32
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: passo 7, imagem 1 %32 HP 15-ay014dx Hard Drive Disk Replacement: passo 7, imagem 2 %32 HP 15-ay014dx Hard Drive Disk Replacement: passo 7, imagem 3 %32
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: passo 8, imagem 1 %32 HP 15-ay014dx Hard Drive Disk Replacement: passo 8, imagem 2 %32 HP 15-ay014dx Hard Drive Disk Replacement: passo 8, imagem 3 %32
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: passo 9, imagem 1 %32 HP 15-ay014dx Hard Drive Disk Replacement: passo 9, imagem 2 %32
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: passo 10, imagem 1 %32
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Conclusão
6 outras pessoas executaram este guia.
Jimmy Huynh
Membro desde: 09/26/17
263 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,929
