Ir para o conteúdo principal
HP 15-ay014dx Battery Replacement
  1. HP 15-ay014dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Battery Replacement: passo 2, imagem 1 %32
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Battery Replacement: passo 3, imagem 1 %32
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
Conclusão
To reassemble your device, follow these steps in reverse order.
Nathan Rapalus
Membro desde: 09/21/17
137 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 767
