Ir para o conteúdo principal
HP 15-af123cl Hard Drive Replacement
O que você precisa
  1. HP 15-af123cl Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-af123cl Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl Hard Drive Replacement: passo 2, imagem 1 %32
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl Hard Drive Replacement, Back Cover: passo 3, imagem 1 %32
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
  4. HP 15-af123cl Hard Drive Replacement: passo 4, imagem 1 %32 HP 15-af123cl Hard Drive Replacement: passo 4, imagem 2 %32 HP 15-af123cl Hard Drive Replacement: passo 4, imagem 3 %32
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
  5. HP 15-af123cl Hard Drive Replacement: passo 5, imagem 1 %32 HP 15-af123cl Hard Drive Replacement: passo 5, imagem 2 %32
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
  6. HP 15-af123cl Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 HP 15-af123cl Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Unclip the cable connected to the drive using an opening tool.
  7. HP 15-af123cl Hard Drive Replacement: passo 7, imagem 1 %32 HP 15-af123cl Hard Drive Replacement: passo 7, imagem 2 %32 HP 15-af123cl Hard Drive Replacement: passo 7, imagem 3 %32
    • Remove the screws from the brackets around the hard drive using a Phillips #00 screwdriver.
  8. HP 15-af123cl Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the brackets from around the hard drive.
    • Remove the hard drive from the laptop.
Conclusão
Victoria Santos
Membro desde: 10/25/21
698 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 426
