Ir para o conteúdo principal
HP 15-af013cl Motherboard Replacement
O que você precisa
  1. HP 15-af013cl Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: passo 2, imagem 1 %32 HP 15-af013cl Motherboard Replacement: passo 2, imagem 2 %32 HP 15-af013cl Motherboard Replacement: passo 2, imagem 3 %32
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: passo 4, imagem 1 %32 HP 15-af013cl Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: passo 5, imagem 1 %32
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: passo 6, imagem 1 %32 HP 15-af013cl Motherboard Replacement: passo 6, imagem 2 %32
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: passo 8, imagem 1 %32 HP 15-af013cl Motherboard Replacement: passo 8, imagem 2 %32 HP 15-af013cl Motherboard Replacement: passo 8, imagem 3 %32
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: passo 9, imagem 1 %32
    • Carefully lift out the motherboard from the laptop.
Conclusão
Stephen Perreira
Membro desde: 09/27/17
787 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S8-G6, Banghart Fall 2017 Membro de Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
Membros da 5
Autoria de 6 guias
Um comentário
i need motherboard hp model:15-bs127ne
elbetel ashenafi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,970
