Introdução
This HP laptop is equipped with a high-definition front facing webcam and allows you to video chat with others or take high-quality photos. Although one of the few things that is likely to fail on your laptop, its nice to know that our guide will make it easy for you to replace your camera in under 20 minutes.
O que você precisa
The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
Remove the cable from under the metal foil.
