Ir para o conteúdo principal
HP 15-af013cl Front Facing Camera Replacement
O que você precisa
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: passo 1, imagem 1 %32
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: passo 2, imagem 1 %32 HP 15-af013cl Front Facing Camera Replacement: passo 2, imagem 2 %32 HP 15-af013cl Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: passo 3, imagem 1 %32
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: passo 4, imagem 1 %32 HP 15-af013cl Front Facing Camera Replacement: passo 4, imagem 2 %32 HP 15-af013cl Front Facing Camera Replacement: passo 4, imagem 3 %32
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: passo 5, imagem 1 %32
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: passo 6, imagem 1 %32 HP 15-af013cl Front Facing Camera Replacement: passo 6, imagem 2 %32
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: passo 7, imagem 1 %32 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: passo 7, imagem 2 %32
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: passo 8, imagem 1 %32
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: passo 9, imagem 1 %32 HP 15-af013cl Front Facing Camera Replacement: passo 9, imagem 2 %32
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: passo 10, imagem 1 %32
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: passo 11, imagem 1 %32
    • Disconnect the display ribbon cable from the motherboard.
Conclusão
Stephen Perreira
Membro desde: 09/27/17
787 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S8-G6, Banghart Fall 2017 Membro de Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 383
