Ir para o conteúdo principal
HP 15-ac121dx Wifi Card Replacement
O que você precisa
  1. HP 15-ac121dx Wifi Card Replacement, Battery: passo 1, imagem 1 %32
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Wifi Card Replacement: passo 2, imagem 1 %32
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Wifi Card Replacement: passo 3, imagem 1 %32 HP 15-ac121dx Wifi Card Replacement: passo 3, imagem 2 %32
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Wifi Card Replacement: passo 4, imagem 1 %32 HP 15-ac121dx Wifi Card Replacement: passo 4, imagem 2 %32
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Wifi Card Replacement, Back Panel: passo 5, imagem 1 %32 HP 15-ac121dx Wifi Card Replacement, Back Panel: passo 5, imagem 2 %32
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Wifi Card Replacement: passo 6, imagem 1 %32
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Wifi Card Replacement: passo 7, imagem 1 %32
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx Wifi Card Replacement, Wifi Card: passo 8, imagem 1 %32 HP 15-ac121dx Wifi Card Replacement, Wifi Card: passo 8, imagem 2 %32 HP 15-ac121dx Wifi Card Replacement, Wifi Card: passo 8, imagem 3 %32
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the Wifi card.
    • Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
    • Carefully remove the Wifi card.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 397
