Ir para o conteúdo principal
HP 15-ac121dx Motherboard Replacement
O que você precisa
  1. HP 15-ac121dx Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Motherboard Replacement: passo 2, imagem 1 %32
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Motherboard Replacement: passo 3, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 3, imagem 2 %32
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Motherboard Replacement: passo 4, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 4, imagem 2 %32
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Motherboard Replacement, Back Panel: passo 5, imagem 1 %32 HP 15-ac121dx Motherboard Replacement, Back Panel: passo 5, imagem 2 %32 HP 15-ac121dx Motherboard Replacement, Back Panel: passo 5, imagem 3 %32
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Motherboard Replacement: passo 7, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 7, imagem 2 %32 HP 15-ac121dx Motherboard Replacement: passo 7, imagem 3 %32
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Motherboard Replacement, Fan: passo 8, imagem 1 %32 HP 15-ac121dx Motherboard Replacement, Fan: passo 8, imagem 2 %32 HP 15-ac121dx Motherboard Replacement, Fan: passo 8, imagem 3 %32
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Motherboard Replacement: passo 9, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 9, imagem 2 %32
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Motherboard Replacement: passo 10, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 10, imagem 2 %32
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  11. HP 15-ac121dx Motherboard Replacement, CD Compartment: passo 11, imagem 1 %32 HP 15-ac121dx Motherboard Replacement, CD Compartment: passo 11, imagem 2 %32 HP 15-ac121dx Motherboard Replacement, CD Compartment: passo 11, imagem 3 %32
    • Locate the CD Compartment as shown and gently slide it out.
  12. HP 15-ac121dx Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac121dx Motherboard Replacement: passo 13, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 13, imagem 2 %32
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac121dx Motherboard Replacement: passo 14, imagem 1 %32 HP 15-ac121dx Motherboard Replacement: passo 14, imagem 2 %32
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac121dx Motherboard Replacement: passo 15, imagem 1 %32
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Onose Aigbe
Membro desde: 01/30/18
390 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G2, Johnson Spring 2018 Membro de Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
Membros da 3
Autoria de 6 guias
Um comentário
Pls can the motherboard of HP - 15 ac-250g5 replacethe board of HP 15 ac-121dx since they have the same body structure.
Emeka Jeffrey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 27
Duração total: 1,342
