Ir para o conteúdo principal
HP 15-ac121dx Fan Replacement
O que você precisa
  1. HP 15-ac121dx Fan Replacement, Battery: passo 1, imagem 1 %32
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Fan Replacement: passo 2, imagem 1 %32
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Fan Replacement: passo 3, imagem 1 %32 HP 15-ac121dx Fan Replacement: passo 3, imagem 2 %32
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Fan Replacement: passo 4, imagem 1 %32 HP 15-ac121dx Fan Replacement: passo 4, imagem 2 %32
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Fan Replacement, Back Panel: passo 5, imagem 1 %32 HP 15-ac121dx Fan Replacement, Back Panel: passo 5, imagem 2 %32 HP 15-ac121dx Fan Replacement, Back Panel: passo 5, imagem 3 %32
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Fan Replacement: passo 6, imagem 1 %32
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Fan Replacement: passo 7, imagem 1 %32 HP 15-ac121dx Fan Replacement: passo 7, imagem 2 %32 HP 15-ac121dx Fan Replacement: passo 7, imagem 3 %32
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Fan Replacement, Fan: passo 8, imagem 1 %32 HP 15-ac121dx Fan Replacement, Fan: passo 8, imagem 2 %32 HP 15-ac121dx Fan Replacement, Fan: passo 8, imagem 3 %32
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Fan Replacement: passo 9, imagem 1 %32 HP 15-ac121dx Fan Replacement: passo 9, imagem 2 %32
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Fan Replacement: passo 10, imagem 1 %32 HP 15-ac121dx Fan Replacement: passo 10, imagem 2 %32
    • Remove fan.
    • Unscrew the two screws holding in the fan.
Conclusão
Replace fan. To reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Onose Aigbe
Membro desde: 01/30/18
390 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G2, Johnson Spring 2018 Membro de Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,450
