Ir para o conteúdo principal
HP 15-ac121dx CD Compartment Replacement
O que você precisa
  1. HP 15-ac121dx CD Compartment Replacement, Battery: passo 1, imagem 1 %32
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: passo 2, imagem 1 %32
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: passo 3, imagem 1 %32 HP 15-ac121dx CD Compartment Replacement: passo 3, imagem 2 %32
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: passo 4, imagem 1 %32 HP 15-ac121dx CD Compartment Replacement: passo 4, imagem 2 %32
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: passo 5, imagem 1 %32 HP 15-ac121dx CD Compartment Replacement, Back Panel: passo 5, imagem 2 %32 HP 15-ac121dx CD Compartment Replacement, Back Panel: passo 5, imagem 3 %32
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: passo 6, imagem 1 %32
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: passo 7, imagem 1 %32 HP 15-ac121dx CD Compartment Replacement: passo 7, imagem 2 %32 HP 15-ac121dx CD Compartment Replacement: passo 7, imagem 3 %32
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: passo 8, imagem 1 %32 HP 15-ac121dx CD Compartment Replacement, CD Compartment: passo 8, imagem 2 %32 HP 15-ac121dx CD Compartment Replacement, CD Compartment: passo 8, imagem 3 %32
    • Locate the CD Compartment as shown and gently slide it out.
Conclusão
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Ashton Martin
Membro desde: 01/30/18
477 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S1-G2, Johnson Spring 2018 Membro de Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 439
