Introdução
Does the case of your laptop have scratches, dents, or you just want to do a deep clean? Well, then this is the guide for you. This guide will direct you through the steps to removing the back panel of an HP15-AC121DX. Doing this will reveal the heart and soul of your computer allowing you to replace more than just the case, and ensure your electronics are dust-free.
O que você precisa
Remove all external devices from the computer.
Remove the charging cord from the computer.
Place the laptop with the back panel facing up and the battery compartment facing away from you.
Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
