Introdução
This guide will detail the process of removing the Hard Disk Drive (HDD) from the laptop.
O que você precisa
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
Using a black nylon spudger, disconnect the black connector that attaches the hard drive to the motherboard
3 outras pessoas executaram este guia.
3 comentários
Can you provide the HDD model number for replacement? Also the model number or description of a compatible HDD with higher capacity.
Thank You
Today, while disassembling my HP 15-BA078DX I had an issue trying to get the shell apart. I didn't realize that there was a screw under each rubber foot by the hinges. It would have saved me a whole lot of trouble had I known that. Very important to get those 2 screws out, otherwise you will risk breaking out the corner on the backside of the keyboard tray....... like I did. Fortunately for me, I was able to use some 2-part epoxy (the kind that works on plastic) to glue the hinge back down to the shell. Had the author pointed out those 2 screws in particular, in the pictorial, things would have gone way easier. Hopefully, this will help the next guy.
