Ir para o conteúdo principal
HP 15-BA078DX Hard Drive Replacement
O que você precisa
  1. HP 15-BA078DX Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP 15-BA078DX Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
    Pergunte ao FixBot
    Comentar
  2. HP 15-BA078DX Hard Drive Replacement, Disc Drive: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
    Pergunte ao FixBot
    Comentar
  3. HP 15-BA078DX Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement: passo 3, imagem 2 %32 HP 15-BA078DX Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. HP 15-BA078DX Hard Drive Replacement, Back Panel: passo 4, imagem 1 %32
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
    Pergunte ao FixBot
    Comentar
  5. HP 15-BA078DX Hard Drive Replacement: passo 5, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement: passo 5, imagem 2 %32 HP 15-BA078DX Hard Drive Replacement: passo 5, imagem 3 %32
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
    Pergunte ao FixBot
    Comentar
  6. HP 15-BA078DX Hard Drive Replacement: passo 6, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement: passo 6, imagem 2 %32 HP 15-BA078DX Hard Drive Replacement: passo 6, imagem 3 %32
    • Carefully pull the shell of the computer apart.
    Pergunte ao FixBot
    Comentar
  7. HP 15-BA078DX Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32
    • Using a black nylon spudger, disconnect the black connector that attaches the hard drive to the motherboard
    Pergunte ao FixBot
    Comentar
  8. HP 15-BA078DX Hard Drive Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the three screws holding the hard drive down to the board.
    Pergunte ao FixBot
    Comentar
  9. HP 15-BA078DX Hard Drive Replacement: passo 9, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement: passo 9, imagem 2 %32 HP 15-BA078DX Hard Drive Replacement: passo 9, imagem 3 %32
    • Remove the hard drive.
    Pergunte ao FixBot
    Comentar
  10. HP 15-BA078DX Hard Drive Replacement: passo 10, imagem 1 %32 HP 15-BA078DX Hard Drive Replacement: passo 10, imagem 2 %32
    • Using the Phillips #0 screwdriver, unscrew the four screws from the holding apparatus.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Can you provide the HDD model number for replacement? Also the model number or description of a compatible HDD with higher capacity.
Thank You
jcoengineer - Responder Compartilhar
Today, while disassembling my HP 15-BA078DX I had an issue trying to get the shell apart. I didn't realize that there was a screw under each rubber foot by the hinges. It would have saved me a whole lot of trouble had I known that. Very important to get those 2 screws out, otherwise you will risk breaking out the corner on the backside of the keyboard tray....... like I did. Fortunately for me, I was able to use some 2-part epoxy (the kind that works on plastic) to glue the hinge back down to the shell. Had the author pointed out those 2 screws in particular, in the pictorial, things would have gone way easier. Hopefully, this will help the next guy.
Eric S - Responder Compartilhar
btw.........you will also need a #1 phillips screwdriver if you plan on removing the hard drive.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 1,620
